Results 1 to 6 of 6
Thread: RA65 High Beam Switch?
    Triple OG Grease Monkey
    Default RA65 High Beam Switch?
    Hey guys, since I've owned my car (few months now) the high beams have never worked when you push the lever forward to make the high beams stay on. However, when you pull the lever back so they stay on for as long as you hold the stick the high beams work.
    The other day I pulled the plastic off from around it and had a look.
    The dodgy pic I drew =
    1. The piece of metal that makes the lever stay in the forward position (the ball bearing and spring in the end of the lever push up against this). Doesn't seem to make a circuit with anything that would make the high beams work.
    2. A button that gets pushed when the lever is pulled back to temporarily turn on the high beams. This button is not pushed when the lever is pushed forward
    3. The ball bearing. w00t.
    The lever does not seem to push or make contact with ANYTHING when pushed forward. The only thing I was a bit suss about was that near the screw that goes through the lever there was a squarish bit of black plastic that looked like it could have been a button but was broken. I tried pushing it in but it didn't seem to move so I'm not sure if that was it.
    Does someone know exactly what activates the high beams to stay on? If you could get a pic or dodgy ms paint drawings that would be hugely appreciated thanks.
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    Default Re: RA65 High Beam Switch?
    well after a quick flick through the workshop manual i found these two pages which might help.. im not game to take apart mine in fear that i'll bugger something up..
    link
    link
    hope they help anyway
    unfortunately they don't show anything about the hibeams thankyou so much for spending the time to scan that in anyway!
    I'll go to the wreckers and pull apart one there to check it out.
    May 2006
    tis ok.. wasn't really doing much else anyway
    gotta love hollies
    Well actually if you wouldn't mind I'll get you to go to the wreckers seeings as you're not busy
    hehe I hate the wreckers... makes me feel so dirty
    anyone?
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 09:38 PM
  2. One for the electronics guru's
    By BradW in forum Tech and Conversions
    Last Post: 01-08-2006, 12:01 AM
  3. Wiring up SpotLights and Fog Lights to AE102 Corolla
    By birdie in forum Tech and Conversions
    Last Post: 28-06-2006, 07:22 AM
  4. Kill Switch In My RA65
    By Steelo in forum Tech and Conversions
    Last Post: 07-12-2005, 04:17 PM
