Results 1 to 15 of 19
Thread: Brake Piston won't budge. What to do?
    Default Brake Piston won't budge. What to do?
    Hi all,
    I am in the middle of changing my brake pads, and I can't get my friggin brake pistons to co-operate. I have tried using a G clamp, and even bought a special tool from super cheaps, none of which have worked. It still has 1cm to go till it's flush, and my hands hurt
    Help please!
    User Conversion King
    NWA
    Default Re: Brake Piston won't budge. What to do?
    multi grips are the go for that, a BIG set.
    also be careful that the master cylinder isnt so full that when the piston does go back in, fluid doesnt spurt all over your paint in the engine bay!
    hello
    Junior Member Backyard Mechanic M.J.H's Avatar
    Quote Originally Posted by DigitalPho3nix
    Hi all,
    Help please!
    So your saying you have pushed it back but not far enough.
    What sort of car is it and does it need to go further to get over the pads or just looks like it needs to go further?
    I'm guessing the pads are sitting in correctly when you try to refit it all or have they given you the wrong pads maybe?
    u tried the trusty wd40 or nut cracker sought of stuff to help loosen things up?
    Junior Member Grease Monkey craigy's Avatar
    Put all the brakes that you had off back together and put your foot on the brake.
    This may dislodge the piston and hopefully you will be able to push it back in.
    If this doesn't work you may have to get the caliper rebuilt, most brake shops have a this facility.
    anyways, good luck
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    won't the teeth on the multi-grips damage the surface of the piston?
    Junior Member Carport Converter 4agte's Avatar
    if these are like the aw11 rear calipers they require you to twist the piston in using a pair of plyers not the easiest thing
    Quote Originally Posted by M.J.H
    I have a Corolla Seca SX.
    Pretty sure all the pads are in ok. I think it has eased out while I have been working on it, so I can't get the original pads in!
    NWA
    if in doub, use a thin piece of ply wood or rubber from a tube or something
    hello
    they can be a bitch to push in if they are not going in straight... with multis, you have to push both sides in at same time...
    but you said you had tried a G clamp already.. maybe it's just rooted or the seals have stuck to the piston
    try with the G clamp again and wiggle from side to side as it gets slowly tighter.... perhaps...
    Western Aus
    get a bit of ply or something, as already stated, and i dunno? try and lightly hammer it in!?
    alternativly, use vice grips or something and apply force to the middle of the piston.
    Eldar.O.
    Wgtn
    Front or Rear.
    As someone said previously, with rear calipers the piston gets screwed back in, not pushed like normal.
    Rear disc. Do I screw it c/w or anti c/w?
    clockwise i think not 100% tho
    GT4 Freak, and Conversion King Squid's Avatar
    OK kinda an obvious one here, are the other wheels chocked and the handbrake off? I had a good laugh when a mate called me over after working for hours on the 'problem' had it fixed in minutes!
    Also as suggested the mechanical portion of the piston (ie handbrake) will often require the piston to twist to go back in. Most cars i have done this on (admittedly not many) the twist has been clockwise, but it is pretty obvious well before your in danger of dropping the piston out.
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    Last Post: 25-07-2018, 12:43 AM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
  4. Brake upgrades for FWD/AWD 5x100
    Last Post: 07-09-2005, 12:38 AM
