like someone said does it have security on the ecu
i need to know what year and model the 2zz came out of and i can tell if it has security
if tis an aussie 2zz then i does have security
if its a jap 2zz then it doesnt have security
i have done a jap 2zz into an echo and had no probs starting it
but they have a funny setup with temp and thermo fan things on the echo so bit of a pain to get working perfect
but try to find out if it is an aussie model 2zz cause yr fukt then heheehe
pain in the ass to get it working if it has security
i will be investing in a diagnostic scanner in few months
it does obd2
and alot of new jap engines these days run obd2 so unless u have a scanner u can not get codes
try leaving ignition on for afew hours then starting it without turning ignition off
this might bypass security if it starts then the ecu has security
not sure if it will work but it does work on holdens
