Results 1 to 5 of 5
Thread: 1GGTE ISCV...can i just fit a breather filter to it?
    Default 1GGTE ISCV...can i just fit a breather filter to it?
    hey guys,
    the idle speed control valve had a hose that ran from it over to the intake piping, behind the air filter....
    now that all of that has been removed,....
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    Default Re: ISCV...can i just fit a breather filter to it?
    theoretically no, the purpose of the iscv is to control idle based on the airflow coming through the throttle body and it obviously gets the pressure from the intake after the air filter, and more importantly after the AFM! that pressure goes into the ISCV and tells it what to idle at.. its pressure dependent, so if you put a filter on it with nothing creating pressure into that valve, its going to idle like crap if at all...
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    ok, so i'll have to plumb it in behind the afm....then it should work as normal?
    rep coming your way when i can spread the luv again,
    cheers, blake
    Junior Member Grease Monkey Jasper's Avatar
    Does your ECU use an airflow meter or a MAP sensor?
    If MAP sensor, the answer is yes, you can just put a filter on it. If it runs an airflow meter then you should ensure all the air that the engine ingests comes through the AFM.
    its the 1ggte pooness with a AFM....so i'll have to tap it in behind the afm then!
    cheers for the help guys!
  1. Breather tanks
    By Mr Ed in forum Tech and Conversions
    Last Post: 30-11-2006, 05:31 PM
  2. 7MGTE ISCV Dilemma
    Last Post: 05-10-2006, 08:19 PM
  3. Oil Filter Interchangability
    By 3sgte in forum Tech and Conversions
    Last Post: 14-03-2006, 12:35 AM
