Results 1 to 12 of 12
Thread: 4AGZE 101 Knock Sensors Issues
    Junior Member Grease Monkey BlueAE86's Avatar
    Brisbane QLD
    Default 4AGZE 101 Knock Sensors Issues
    Hi
    Does anybody know of a way of getting around the Knock sensor when using a factory computer setup.?
    Junior Member Grease Monkey Jasper's Avatar
    Default Re: 4AGZE 101 Knock Sensors Issues
    What do you mean by getting around them?
    replace it with a new one, run 100ron fuel, and set the base timing to 10deg.
    Brisbane QLD
    What i mean by getting around it, is tricking it to thick that it is working properly.
    The reason is as you turbo these in which case mine is they sensse alot more problems and therefor think there is a problem .
    I always run premium fuel also.
    Any other ideas ??
    If you install a fibre washer under it the vibrations should be damped a bit...
    Find out somehow what resistance it needs when not pinging and replace sensor with resistor and then earth. You should be able to use a multimeter on the wire when running under pefect conditions.
    This is only by thought, i have never tried this/nor am i an auto elecy.
    Jun 2006
    Tasmania
    I doubt the knock sensor goes to earth, prob through a resistor n back to the ecu
    New Zealand
    i know many many ppl using them with no issues.....
    maybe some more tuning is needed?
    Quote Originally Posted by BlueAE86
    Hi
    unscrew it and tape it to the loom??
    my 4agte has worked fine with the factory knock sensor since 2002.
    « RČ» Blinky, last time i had a knock sensor in bits it appeared to me to be a small peizio microphone that does need to be earthed.
    Well it would make sense that its screwed into the block so it would utilise that connection to earth. Just like every other sensor.
    Jun 2006
    Tasmania
    umm temp senders?
    Not all sensors need an earth
  1. microtech +1j knock sensors
    By yann in forum Tech and Conversions
    Last Post: 30-08-2006, 02:18 PM
  2. Faulty Knock Sensor - 4AGZE
    By LoCo in forum Tech and Conversions
    Last Post: 20-07-2006, 02:39 PM
  3. Dual knock sensors
    Last Post: 11-07-2006, 09:24 PM
