Oil is heavier than air,we can all agree.So,to allow the oil being carried by air [in suspension] to seperate,we need to slow the air.once the air loses speed [velocity] the oil or water or any liquid in suspension will fall due to gravitational forces being stronger than the high speed air flow in a small diamater pipe.
This is why the catch can needs SIZE.the air cant slow down in a small catch can.Small cans are BULLSHIT.Any can that does not need emptying regularly is also BS.Just because you can buy it and its called a catch can doesnt mean Anything,its required to understand how things work before parting with your hard earned.
Bling is not worth 2 cents here either.It may as well be a 3 litre plastic bottle,provided the fast moving oil laden hot air from your pressurised crank is allowed a place to cool and slow down it will drop its oil content as previously mentioned.
Another factor is the octane level reducing properties of oil mist.
If you consider for a minute the amount of "blow by" that occurs by super hot exhaust gasses escaping past your piston rings thus pressurising the crank.In many older engines you may have noticed the vacuum hoses meant to remove these gasses via vacuum into the inlet become hard and blocked up over time.
This factor then becomes responsible for oil leaks etc as the pressurised gasses will then push past oil seals etc creating all sorts of problems.
The ideal solution is a large catch can hidden inside your gaurd with a one way valve allowing oil collected to find its own way back to the sump via a hose.Definitely much better to have it vacuum assisted.There is nothing clever about polluting and nothing wimpy about doing things properly.Those who disagree should go and have a lovely oil saturated winnie red lol.
