Well, it's been a bit slow over the weekend. Had to do some house renovation-type stuff which chewed up all of Saturday and half of Sunday (today). Back to work tomorrow (for a rest and I have some small things to do to allow me to move forward with this conversion - in particluar a plate to house the fuel gear under the Hilux.
I got some U-brackets from Bunnings. I had to buy a packet of six (6) - typical mass-market nonsense. This will locate the BOSCH pump on the plate, along with the (new) fuel filter.
The Chassis Black had thoroughly dried so I put the suspension back in - drop blocks and shocks - and looked at re-routing the wiring for the rear lights and towbar which I'll wrap in some black convoluted tubing to keep it tidy.
I also managed to get the fuel tank back in and wired up, although I'm going to have to partially drop it again to connect the fuel pump electrical connection.
The placement of the fuel tank is another one of those Japanese marvels of ingenuity. You don't have too many options for putting it in and it really requires two people as you have to raise the front to locate the three bolts, simultaneously raising the back and also fitting the fuel filler neck tubing. I ended up taking the fuel filler tubing out, putting it on the fuel tank then raising front and rear, locating a bolt in each, then connecting the filler tube. Almost like Rubik's Cube![]()
To do this week:
Fabricate plate for fuel pump and filter, using original undercar mounting points
Mount pump and filter, and connect with EFI fuel hose and hose clamps
Print off Bullfrog's ECU schematics on A3 paper for further study
Fabricate intake bracket to hold AFM and install
Install Odyssey battery - either a PC545, PC535 or PC680
Connect gauges from cabin to lighting power
Install Boost gauge
PS. If you are wondering about the rear tailshaft - it'll come out later for a cleanup and lick of paint![]()
Two problems:
Small pinhole leak in sump
Clearance of the power steering rack as the engine settles on its mounts
Peter
but I'm sure it's only a matter of another weekend or two and (hopefully) I'll be able to enjoy this conversion.
