Results 1 to 15 of 22
Thread: my 1st go at rebuilding an engine**DONE ATLAST
    Default my 1st go at rebuilding an engine**DONE ATLAST
    well guys this is my first go (me and my dad) at rebuildin a engine .
    engine is a 18r dnt flame me for it i kinda like the 18r
    ok so me and my dad hav started to strip the block annd taken the head off
    The head
    the cam suppose to be lumpy but were not sure
    cheers luke
    u all have a great xmas
    Default Re: my 1st go at rebuilding an engine
    That's a massive overbore. Have you checked this is real (even with some basic Vernier calipers)? Do they make 120 thou oversize pistons for the 18R? If not, what did they use?
    sorry i jus found out its 20thou i got the engine of some guy in sa for 150 jus gonna do rings bearings gaskets fix her up
    by the looks mate, yes that cam is lumpy.
    If you want to be sure send it to my work and ill cam doctor it for you.
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    hey mate. keep going with the pics....i'm gonna have my first go at rebuilding soon too and i have an 18r too +Rep
    Quote Originally Posted by Hash_ra23
    cheers dude i keep goin with the pics like when im changin ring and bearings
    judging by your photo's it looks like the engine was getting water into number one cylinder aswell.
    Quote Originally Posted by jeffro ra28
    agreed. I've seen this happen on two 18R-G blocks as well. Be sure you get the block and head decks machined.
    I also recommend getting a balance and whatnot when you have the bottom end at the reconditioners.
    and make sure you include the flywheel, pressure plate and clutch that you'll be putting on the engine - balancing will make the tractor motor rev a bit smoother.
    ok ive cleaned all the pistons
    cleaned all the head in an acid bath and cleaned valves
    got all the parts for a rebuild chain tensioners rings bearings waterpump etc $280
    shood have it in by middle jan late jan
    cheers luke
    User Conversion King
    NWA
    should go well with those little bits, and the freshen up.
    might be worth picking up a cheap haynes manual incase you need to double check a clearance etc
    the 18rc in my daily RA40 is suprisingly powerful. bulk torque off the mark that goes all the way to 5K. bit of a phreak motor compared to the other four 18rc celicas ive been in
    sits on 1500rpm in 5th gear no probs.
    are you going to open up the inlet (carby) and exhaust (extractors).
    i found a HUGE benefit from mechanically connecting the primary and secondary butterfly.
    it might even be worth investing in a weber if your going to this much effort.
    did you get a decent amount of material shaved off the head? im convinced a rise in compression would do wonders for this engine! it would be best to ask the forums to find up how much material can be safely removed though.
    hope it goes well
    hello
    i have just discoverd the is a small crack in the head and a mechanic mate said you will have to get that welded up so does anyone no a place where i can get i done a a fair price (im in sydney) i wanna keep this head cause last owner spent some good money on it getting it ported and polished (as some of you a aware with cast iron heads ) and the big cam
    cheers luke
    I wouldn't weld it up, for the cost of a replacement 18r head, I'd get one.
    Facebook | LinkedIn
    welding is total hit and miss. Yer sometimes it works. Where abouts is the crack?
    thats the crack (sorry bout crappy fone pic)
    but so far striped the block and soon to be replacing rings bearings etc
    Cheers luke
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. Cooling Systems - Overheating Problems.
