Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: 1UZ injector question
    Default 1UZ injector question
    I read that the 7mge NA injectors are an upgrade for the 1UZ engine since they are rated at a higher output. Ithink it was 315cc/min for the 7M versus 255cc/min for the 1UZ.
    My question is why? Both engines are about 500cc per cylinder. Why would the 7M need bigger injectors from the factory??
    Default Re: 1UZ injector question
    it may not have 'needed' them, it was probably for performance. Remember, the 1uz out of the factory was a slug, a slug with tons of potential though!
    Penrith BC
    'upgrade' ?? as in just 'plug them in' ? lol... the engine will drown in fuel
    and the 7mge injectors are only 295 at the rail pressure that the 1uz are rated at.
    ../delete/ban
    tech moderator
    and perhaps different factory rev range...
    smaller injectors can be used at lower rpm, because there is more time available to inject.
    Junior Member Grease Monkey Jasper's Avatar
    7M has a 'performance' wide valve angle 'G' head, 1UZ has an 'economy' narrow valve angle 'F' head. The 'G' head has greater flow potential, so needs larger injectors.
    Penrith BC
    and that ^^^^^ is all bollox
    ../delete/ban
    tech moderator
    Dreamer Backyard Mechanic millsi's Avatar
    ok, the standard 1uz injectors are 251cc's. yellow 7mge (early) are 295cc's and light green 7mge are 315cc's. these are a direct plug and play upgrade for the 1uz. i will be using the light greens with my turbo 1uz (low boost)
    Junior Member Backyard Mechanic jezza323's Avatar
    yes they are a direct plug in fit but without some sort of fuel management the engine will drown as per eds statement above
    You can't just compare injectors based on cc/min at a specifed rail pressure....well we can but manufacturers can't. We can as generally speaking we aren't too worried about emissions and perfectly smooth driveability.
    Spray pattern, fuel pressure, injector duty, open time, impedence, solenoide type etc etc are all factors considered and makes for quite a complex matrix. Throw in an available parts bin a bean counter can scab from and what injector appears in what engine isn't worth worrying about, other than which ones might be suitable for our needs as an upgrade.
    im running a stand alone btw.
    Penrith BC
    Quote Originally Posted by millsi
    the numbers are different because the test rail pressures are different. those two injectors flow the same
    ../delete/ban
    tech moderator
    Millsi, why dont you use the 440cc/min injectors from the 7MGTE?
    Sort of offtopic, but thanks to kingmick for neg repping me for my previous post, with the following comment:
    "ive read some crap on toymods, but that just about takes the cake! i take it you know nothing at all about engines and the 1uz!"
    Quote Originally Posted by Jasper
    I wonder which point he objected to.
    If its the G versus F code thing then I would have to agree with JASPER.
    So what degree are the valve angles at? and what is the current race v8 angle at?
  1. 1uz ITB manifold adapter plate .dxf file
    Last Post: 29-10-2021, 10:49 AM
  2. 5M tacho with 1UZ motor ???
    Last Post: 16-09-2006, 11:46 AM
  3. 1UZ bottom end bits
    By mrshin in forum Tech and Conversions
    Last Post: 25-07-2006, 08:58 PM
  4. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 11:16 AM
