yep i am running an aftermarket ecu. just trying to keep things simple!
There is a ridge on the injector which can be ground off to make them fit the plugs on the 1UZ harness. As for the impedance, aren't you running an aftermarket ECU?
The 1UZ clips fit straight over the 7MGTE injectors once you grind the locating tabs off the injectors.
Impedance is no worry either with aftermarket ecu.
I know, coz I have this combination, as does Jasper.
nice!
the words 'millsi' and 'grinding' dont go together well!
It's only a plastic tang!
id prolly use an angle grinder!
anyway im sure the 7mge jobbies will be fine, got to have sumpn to stop me turning the boost up! lol
How about the word filing?
Seriously, I think I used the Dremel on it, but you could use a file no problems.
Isnt a 1 UZ just two 3 SFE,s joined together , hehe
Probably, but it sounds better
pretty much but the 1uz is 87.5 x 82.5mm and the 3sgte square boss is 86 x 86mm
and 2 x 3SFE would struggle a bit to make 400rwkw :-)
Millsi - it's a hat trick mate, i also run 7MGTE injectors. I restrained myself and used a file to remove the tab so no grinder unfortunately![]()
Now that things have settled down I have two straight forward questions.Originally Posted by JustenGT8
Anybody want to sell me a set of standard 1uz injectors??![]()
Anybody want a set of standard 7mge injectors for their 1UZ ??
I WILL START A THREAD IN THE CLASSIFIEDS SECTION
