Results 1 to 6 of 6
Thread: 1G-GZE turbo oil feed
    Junior Member Grease Monkey Jayem's Avatar
    suomi
    Default 1G-GZE turbo oil feed
    Has anyone drilled this oil feed hole. It doesn't go thrue into oil canal in GZE. I'm suspiciousto that it could be drilled. Is there difference in GZE and GTE head cast? Hole in the front is for coil packs and I would prefer to drill rear one for turbo oil feed...
    http://img.photobucket.com/albums/v6...d/P3310006.jpg
    http://img.photobucket.com/albums/v6...d/P3310007.jpg
    Default Re: 1G-GZE turbo oil feed
    you cannot get your oil feed from there, there will not be any pressure..... does the engine have an oil pressure sender?
    if so buy a T piece and source it from there.
    hehehe be like getting oil feed from the breather!
    hint, you cant get water pressure reading out of the overflow bottle or fuel pressure reading from the fuel tank!
    thought it might help with the other gauges!
    As said, that is 110% NOT going to work as a high presure turbo oil feed...
    suomi
    Heheh.
    I thought those two holes were the oil feeds for twin turbos in 1G-GTE. I think the front one could be used to take high pressure oil from it for the turbo.
    Nope, those holes are to hold on the hook for attaching it to an engine crane.
    Last Post: 11-10-2014, 01:02 AM
  2. Turbo oil feed
    By turbocaldina in forum Tech and Conversions
    Last Post: 24-10-2006, 05:21 PM
  3. 3t-c oil feed + return for turbo
    Last Post: 30-08-2006, 03:58 PM
