Results 1 to 15 of 20
Thread: 7mge to 1jzgte
    Default 7mge to 1jzgte
    can anyone help with links or info regards the 7mge to 1jzgte conversion. Looking for electrical info for which wires go where. Ive seen ones for 7mgte only.
    Default Re: 7mge to 1jzgte
    Quote Originally Posted by zork
    what exactly are ytou having problems with? 7mge and 7mgte are very similar...
    Western Aus
    ok, first off you might actually provide some info, even if its the CAR its going into.
    although im going to assume supra.
    then, you need to state the YEAR, im going to assume pre 89.
    in that case, the pre 89 7MGTE wiring diags will be helpful, as most of the wires are same or similar.
    just dont go joining up all the wire colours together and hoping its gonna work.
    Eldar.O.
    yeah sorry. mine is a 86.5 ma70, 7m-ge.
    Still having probs with this? Maybe I can help recently done 1j conversion and know someone whos done 1J conversion into early Ma70
    1JZ 1989 MZ20 Soarer - 3 week conversion all by myself
    200 rwhp 1977 MX36 Cressida wagon - off the road and needs a new home
    1986 Tarago campervan conversion on the go.
    2011 Toyota Aurion
    Quote Originally Posted by yotamotion
    thanks heaps. i just want to know re: wiring diagrams for early MA70 (86.5 -87). We need to know what wires go where, can we use my original dash & how, & any other electrical details possible.
    Ok will find the wiring diags for that model and email them in pdf to you,first of all I need to know what car the 1J came out of and what year, and how much of the 1J setup do you have? Is it just the engine, box and ecu or do you have a front cut with a dash and everything?
    2011 Toyota Aurion
    The 1jz is out of a jza70r supra. It is a complete half cut manual. It has the analogue dash. Mine is a ma70 auto. I was hoping to use my dash cluster if possible. Really appreciate your assistance mate as i know this is gonna be the 'hard bit' and most people seem to have done the conversion on later models, having trouble finding the early model info. Thanks again, Steve.
    Xistant
    Guest
    zork why use your dash?
    whats wrong with the jza70 dash?
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    http://www.1jz-gte.us/
    all you need right there
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    Xistant
    Guest
    zork, come around to my place tonight and i'll give you every wiring diagram possible all printed out.
    sweet, thanx K. ill call you this arvo.
    Western Aus
    Quote Originally Posted by 2DRFT
    yeah, and spend six days piecing everything together.
    ive wired two of these bastards up so far,
    basically, to make the car run off the key (including fuel pump), you need the two thick ass wires behind the glove box, the medium sized wire, and i think another 2 small ones.
    then theres the EA2 connector in the engine bay, with 3 wires to run your alternator (not including the big thick one that goes onto your battery) and i think a further 3 or 4 for your ignitor.
    i have the diagrams here, but i cant be bothered confirming.
    obviously this wont make it run quite like sideshows jobs (i.e. properly) but will get a manual car going, and driveable, additional wiring is needed for ABS etc. etc.
    then youve got some more wiring (depending on whether digi dash or not) to wire in your boost, oil, temp etc. guages, check engine etc. lights, and your tacho, as long as youve got your speedo cable (i dont know whether your original would fit if your car was manual as im not sure if W58 and R154/A340 are the same) plugged in and obviously your fuel guage is already wired in.
    a decent job (YOU MUST SOLDER/CRIMP THESE BASTARDS!!@##@!##@!#!%$) should take you half a day, but at least it'll be done right.
    Eldar.O.
    id just prefer to use my ozzie one, with the 240kmh speedo, maybe i can change to speedo only
    would also like to retain the oil pressure guage, rather than the light in the jza70 dash, i know id loose the factory boost guage, but its not the best boost guage anyway. Id prefer something in psi.
  1. 5MGE and 7MGE Oil Pumps
    By Art Racing in forum Tech and Conversions
    Last Post: 07-10-2006, 06:43 AM
  2. Project 7mge to 7mgte %90 done -%10 need help
    By Mk3_supra in forum Tech and Conversions
    Last Post: 12-08-2006, 10:38 PM
  3. JZA70 1JZGTE Engine manual ? Anyone
    By 1200det in forum Tech and Conversions
    Last Post: 12-08-2006, 09:57 AM
