Results 1 to 4 of 4
Thread: difference between Black and Silver top.
    Jun 2006
    Question difference between Black and Silver top.
    What is the difference between these models of 4AGE? Also did the 4AGZE ever come out with a 20 valve head or would you have to sorce one for it and is it a straight bolt on? What model did the quad throttle bodies come out on FWD or RWD and which engine.
    Thanks
    T'ville, QLD
    Default Re: difference between Black and Silver top.
    the 20v head will bolt on to a gze block but the pistons have to be fly cut for the extra valve, the BT has lighter and weaker internals and uses MAP sensor the ST has stronger internals and uses AFM, both had quads and were only in wrong wheel drive setup
    and USE THE F#$KING SEARCH BUTTON!!!
    2T out 4A in....
    Jun 2006
    Thanks i didnt even know there was a search button.
    In anycase i was planning on getting a 4AGZE putting a 20V head on it and getting rid of the supercharger and putting a turbo charger on what are peoples toughts on that? What sort of power would i be looking at getting out of that? and would that be the best way of doing it?
    again - pls search.
    This question is one of the most common questions ever. Also search www.twincam.info forums
    LOCKED.
  1. 20 valve black top ecu P/N
    By cambelt in forum Tech and Conversions
    Last Post: 30-05-2006, 01:57 PM
