Results 1 to 9 of 9
Thread: 3S GTE Block and Head swaps
    Jun 2006
    Default 3S GTE Block and Head swaps
    Im wondering whether any one has some experience or knows whether i could fit a ST165 head to a ST185 block? Any advice or information would be much appreciated.
    Damo
    Default Re: 3S GTE Block and Head swaps
    Yeah the heads and blocks are interchangeable.
    I put a st205 head on a st185 block.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Jun 2006
    do you reckon I'd be able to put a 165 head on a 185 block?
    Yes should be no problems at all.
    Yes they interchange for a fact.
    Jun 2006
    Excellent, thanks heaps for the help mate!
    May i ask why you would be doing this conversion ???
    Is this a turbo setup ???
    J
    1990 Toyota Celica GT4
    POD Filter, 3" Dump Pimp, 3" Exhaust System with Cat, FMIC, Turbosmart In-car Dual Boost Controller 9psi running, 15psi switch, looking at more to come
    I too put on a 205 head onto a 185 block, no issues there.
    Only thing to watch out for, is make sure you have the correct head gasket for the job. You'll need the MLS (multi-layer) head gasket from Toyota but please make sure it's the correct one! I had overheating issues on mine (partly) because the head gasket didn't have enough holes for the water galleys, and thus the water couldn't pass through as needed between head and block. Even if you have the 165 head and a 185 block, typically (only from what I've seen) the later generation head/block will usually have more water galleys and thus require a newer styled head gasket.
    I'd probably go for a head gasket from a 185 GrpA which I believe has the same amount of water galley holes as the 205 does. Even if your current head/block doesn't have the use for these, it's better to over-compensate on this rather than having an overheating engine.
    Cheers.
    TRIKKE | Video
    Here's what I mean...
    ST185 block..
    ST205 head..
    you can see there's a hole there on each cyl in particular (on the head) which isn't catered for on the block. small thing to ponder, but saves a world of grief.
    TRIKKE | Video
  1. 2T Head and 3T Block, standard items - any problems?
    By -NiCkeL- in forum Tech and Conversions
    Last Post: 09-11-2006, 02:29 PM
  2. Matching your head to your o-ringed block.
    By PHOBIA in forum Tech and Conversions
    Last Post: 09-05-2006, 03:14 PM
  3. GZE block 20v Head. Will it bolt up?
    By omy in forum Tech and Conversions
    Last Post: 06-05-2006, 12:57 AM
  4. 5M-E head on 5M-GE block
    Last Post: 30-03-2006, 11:42 PM
