Results 16 to 30 of 45
Thread: BBQ in my engine block - all invited
    Default Re: BBQ in my engine block - all invited
    Dominator offers a wide range of expertise in Engine Reconditioning and machining. Engine reconditioning by known professionals is now available to members of ToyMods at a discounted price.
    ToyMods members will recieve:
    Trade Price on Machining.
    Trade Less 10% up to $1000
    Trade Less 20% on any jobs over $1000.
    (price is for single invoice only)
    Phone: 9681 3462
    Fax: 9632 3498
    If in doubt power out
    Junior Member Grease Monkey minxgirl's Avatar
    Thanks for that
    Quote Originally Posted by minxgirl
    Yeah - I agree there. Might just make a mess I cant finish
    Bah! You gotta start somewhere, its not all that difficult with a little mechanical thought to it, and some motivation. What you need to do is get another 2T-G cheap, rebuild that one, then once its rebuilt (cos youre not gonna wanna rush it for your first time) take your car off the road to swap it. You can either leave your car to sit whilst you rebuild the second engine, or drive around on it some more (just keep the oil up to it you'll be fine - drove my 3T around for over a year using 1L of oil a day MINIMUM, and it was still going fine the day i pulled it out).
    If you get a shop to rebuild it youre going to be up for some big $$. Though I do suggest you send your head to a reconditioner to clean it up and check the valves through, relap them and put all new valve stem seals in. Youre going to be looking at around $400 for that alone
    Otherwise a new set of rings, a quick hone (hopefully you get one with a good bore), and some new big end and main bearings and you should be good to go. Oh and hopefully your timing chain guides are still good, a set of guides and chains is gonna set you back $500 nasty but worth it if you plan on keeping your car for a while.
    Benefit is if you rebuild an engine, at least then you know its going to be fine for quite sometime, and shouldnt get too many problems for it.
    .....And is there beer at this BBQ?? If you were up my way, i'd help you rebuild this engine, but theres plenty people around here willing to help you out and give you a head start
    Toyota Car Club (Qld)
    Well...I rang Dominator - theyre nice helpful people - more so than the locals at least!!! However he says he cant get parts for the DOHC model? He said most single cam engine parts would likely be interchangeable - but he wasnt sure about the gaskets, guide plates, tensioners, pistons, and so forth. Obviously people here have rebuilt these before - so where did you get your stuff? What did you use?
    Silli - I wish I was there too! Id love to put some of my holidays into drinking and playing cars with ya Would be awesome
    If you decide to throw in the towel I'd take the 2TG head.
    Don't throw in the towel though, give it a go. you can buy the workshop manual for the 2TG off ebay for $44 (just type 2t-G into the search bar)
    Jrodan
    Double posted oops!
    But I was gonna also mention anyway, River has workshop manual scanned in, ask him to send you a copy on CD, and you'll even get a post-it note stuck to the case with a peace sign drawn on it! He's such a hippie!
    http://www.swmotorsport.com.au/
    They have a full gasket set for $150.... but im pretty sure my supplier, just the local aussie auto, could get me 2T-G parts, they had listings on most things, so you should be able to get parts pretty easily.
    If not, you will probably find almost everything through stewart wilkins motorsport...
    I get trade price through my supplier (cos my dad and I are forever buying car parts ) and i think sw even worked out cheaper a lot of the time Bonus!
    Quote Originally Posted by jfallen
    got one right here, but thanks.
    I checked out sw motorsport and they had a few of the things there listed that the guy reckoned he wouldnt be able to get, thanks again Silli Chick
    One option would be... Take the engine out yourself and strip it down completely (this doesn't take a lot of mechanical experience). - Just be careful everything you undo you label it/box it/etc so you know where it came from.
    Send the parts off to be reconditioned - block, head, etc as you'll never have the equipment to do that yourself.
    While they are away getting machined.. Order your new gasket kit, rings & bearings from Stewart Wilkins Motorsport.
    When all the engine bits come back machined and you have all the new bits n pieces. Send a call out to any Toymodders in your area to come around and help re-assemble the engine.
    Put on a BBQ & drinks and i'm sure you'll have people with experience come lend a hand!
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Never buy things like bearings until after the machining is done - they may need to enlarge the bearing journals or undersize the crank if there is scoring to get rid of.
    Yeah good point.. Well maybe whoever does the machining get them to supply the bearing & rings.. If they freak out about getting parts especially the gaskets tell them to talk to Stewart.
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    how much are you prepared to spend? also where are you?
    Jill,
    Just to address the basics first, what engine oil did they use ?
    When does it blow the blue smoke ? Is it only straight after you start it, only once the engine warms up ? Ie no smoke for 30 seconds or so or is it just blue smoke all the time.
    The first thing you need to do is try and work out what has failed and then decide just how much you want to spend and how far you want to go with the car. If you have the workshop manual check over your engine breathers firts, make sure they are not blocked and that the engine is breathing properly.
    Then you should re-check the compression, remeber to hav ethe engine warm and the throttle wide open during the test.
    Once thats done we have a small insight into the scope of your issue.
    Then you need to decide up front what you want to acheive this time round. Is now the time you chase the extra power you were wanting or do you just rebuild to standard and redo the job at a more convienient time.
    As for parts, most of them are out there if you know where to look. If you decide to ship the engine and pay to have it built then I would recommend Graham Wilkins (Stewarts brother) He was racing these engines when they first hit our shores and knows then inside out. His buisness is Wilkins performance engines at Seven Hills - 02 9674 7037. Make sure you tell him Rod from SAS sent you.
    Once you decide if you want to rebuild it as standard or for some extra performance let me know.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    A big thanks to everyone who has responded in my thread.
    Im currently trying to work out how much money (in total) would need to be spent on the celica to leave nothing serious wanting...theres electrical issues, rust & panel damage issues, and the engine...
    Im a bit dismayed by it all $1500 of miscellaneous work later after being assured the engine was "fine" by those bastard-arse mechanics I used to go to...That would have gone a long way towards more important things!
    I love the car but Im not sure whether I can afford to fix it and keep it yet - so Im just weighing it up right now...I will get back to this thread later and respond to everyone I havent already responded to then. Thanks again everyone - so many helpful great ppl here.
  1. Toyota R Engine History
  2. Engine Conversion AL25 Tercel -> 4AGE
    By Starfire in forum Engine & Driveline Conversions
    Last Post: 01-06-2008, 10:17 PM
  3. MA70 --> JZA70 Conversion
  4. 4AGE 16V block vs 20V block.
    By WHITCHY in forum Tech and Conversions
    Last Post: 21-02-2007, 09:05 PM
