the ones i've compression tested were around 120 - 130 psi range.
compression ratio 7.8:1
3tgte don't have a diagnostics mode
i've written up some tech stuff on 3tgte here
http://www.toycrazy.net/tech/3tgte.htm
from what you're explaining it could be a range of faults.. ones i'd look into are:
afm plug not clipped on? are you missing the metal wire clip off it?
air leak.. any leaks between the afm and the engine, including the intake manifold and breather pipes will cause problems.
blocked/dirty injectors will give an erratic idle but is usually is consistantly erratic.
check plugs on the injectors are plugged on properly.
pull leads and check the terminals in the dizzy are not corroded or the leads themselves.
replace the green temp sensor on the thermostat housing and see if that fixes it.
is afm flap sticking? take afm off and push flap with your finger and see if it opens smoothly.
try those![]()
