Results 1 to 15 of 22
Thread: Dump pipe hitting steering - MA61 1JZ
    I have a pet Backyard Mechanic Gibbon's Avatar
    Aug 2006
    Default Dump pipe hitting steering - MA61 1JZ
    Hi
    Test fitted the 1JZ into my MA61, with a after market dump pipe installed.
    this is what happens:
    Any good ideas on a solution? - I'd like to keep the dump pipe if possible.
    thanks
    David
    wget -r http://www.toymods.net | grep -i "1jz MA61"
    1 Result found:
    Gibbons MA61 + 1JZ
    Default Re: Dump pipe hitting steering - MA61 1JZ
    modify it, get a new one.... put a dint in it to stop it touching if you want to keep it so bad.
    Quote Originally Posted by Gibbon
    Drive car in a straight line.
    and I thought my extractors were close to the steering column!
    Basically some form of modification. Hammer love in the side might give you some clearance at the cost of reduction in diameter. Otherwise you could try to heat it and bend it, or cut and weld at a different angle. Either way, you can't leave it like that
    if you want to keep the dump, remove the steering component that its hitting. .
    i wouldnt think one would need to get opinions on how to fix this problem.
    Who said Toymods isn't helpful?
    Get a new dump. Even if you can modify that one to give adequate clearance it will still be too close. Dump pipes get HOT!
    Aug 2006
    Quote Originally Posted by gianttomato
    Yeah - a real bunch of champs
    The only two things I can think of is either raise the engine up (spacers in the mounts) and see if it clears, or, as suggested, replace the dumps.
    1 Result found:
    Gibbons MA61 + 1JZ
    raise the engine?
    A dump pipe cannot cost you that much... get a new one (or weld new bits on to your current one)
    Aug 2006
    Quote Originally Posted by Draven
    Yes - looks like a new dump pipe then. Damn - it was a really good one too.
    1 Result found:
    Gibbons MA61 + 1JZ
    Maybe good for flow but not good for you
    You could mod it, but you would have to look at if it was cheaper to sell it and get a custom one made.
    is that one of those ebay ones, direct replacement of the standard cast ones
    The boobs are back
    The one that 'petespipes' makes for the JZX83 may have better fitment?
    he doesnt make them anymore
    The boobs are back
    Petespipes did mine....
    Don't think he made a template tho!....if mine come off he will be measuring them up for future reference
  1. 1JZ / 2JZ into MA61 / MZ10 Guide.
    By Joorsh in forum Engine & Driveline Conversions
    Last Post: 03-09-2013, 10:29 AM
  2. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 05:08 AM
