Just wondering, did you reset the ECU when doing the change?
Also you could maybe put a 27K(if using a 500R in series) resistor in parallel with GND and +5V to bring the overall impedance of the circuit back down to 5K without affecting the voltage dividing circuit. Maybe the ECU measure the current flow through the TPS circuit too, nominally 1mA but now 0.9mA with a 500R in series. I doubt the ECU would care that much though. I only thought they monitored the circuit as a voltage divider, hence why a 10 or 20K TPS should work just fine.
Good luck.
