hi all...
anyone know how to identify rear differential code besides printed at small aluminium plate?!
any indication on the diff housing?!
hi takai...Originally Posted by takai
i attached herewith my ST185 n SXE10 clutch MC pix... do u have the pix of ur AE86 clutch MC "final product"... 10mm shorter...?! is it safe?! will it burst if the end has been shorten?!![]()
Originally Posted by CrUZida
hi UZida...
60psi?! e.e..rr..r... -_-"
may i have bill's email?! i would like to consult him bout this... n what type of fuel pump is he using for his SE86?!
Originally Posted by Mos
hi... moz...
thanks for the diagram... i think i will check out the local chop shops here to look for anything similar...
norb...
this is my shifter position...
from the pix below... i dont think i can push further toward the firewall after i shorten the clutch MC... the shifter cannt go further to the back... the Xmember n the oil sump... the brake MC n the inlet plenum... bra bra bra... *headache*
this is what i try to do for the Xmember braket...
any good suggestion to clear all the issues n push it further to the firewall...?!
hi all...
IMHO you can go closer on the sump - mine will have a lot less room... (fingers only, no hands).
Diff ratios: spin and count, nothing on the diff itself AFAIK.
Mos.
cut some out of the sump and just add it to the front, ive had to do this is most of my engine conversions, a good opportunity to get a bit more capacity in teh sump too!
