You will definately need a new O ring for that driveshaft. it might even need a speedy seal over the shaft to get a proper seal.
Get some Castrol Syntrax gearbox oil, takes 3.2-4 Litres.
Hi All,
Just noticed the check gear box oil level indicator on the dash has started coming on, so after a bit of investigation it would appear that the casr has developed a leak from the side of the gearbox, or more specifically where the drivers side driveshaft enters the gearbox. I have no manuals but am assuming that there's some sort of rubber o ring sealing inside there. Only bought the car yesterday, but the previous owner said it needed a cv boot for the roadworthy, so whoever did the work has obviously done something wrong. Can somebody in the know provide details of whatever part I'm likely to need or better still any schematics of this area of the tranny
Also, what gearbox oil does everyone recomend.
Chaps![]()
Bryn
Homebrew, triumph triple, turbo aw11
Any ideas on part numbers mate. Already been down to see MR T, but no help at all TBH.![]()
1987 AW11 White over Grey Tin Top Supercharger
Previous cars:
1987 Aw11 Grey Coupe MK 1.5 Rev 2 3SGTE
1986 Aw11 Black Coupe Supercharger Conversion
1990 Aw11 Black T-Bar
1990 Aw11 White Coupe
When i get home i can have a look in the BGB for you. Im sure someone may be able to help before then as im gonna be at work till 8pm! DAMN YOU LTO tape drives.![]()
road and track stock the seals and know what hey are.. unlike most toyota dealers
http://www.roadandtrack.net.au/
