Results 1 to 9 of 9
Thread: injector sizing?
    Default injector sizing?
    G'day guys
    I want to get my fuel system finalised and finished before December,
    The engine is a 3T-G Running a Microtech ECH, 45mm INjection perfection ITBs, hot cam,double valve springs, nitrided valves, ports, approx 9.7:1 comp ratio, all been balanced etc
    I was wondering what sorta injectors i should get, casue they are quite a distance from the valves i want a fine pattern, but im more worried about flow, i was thinking of just getting 4AGZE injectors to get it running, then do some research on injectors with the right flow and pattern
    suggestions?
    ATM i have a few sets of bosch 280 150 736 laying around and also can get injectors that were used in the BMW E30 325i (cant rememebr engines, i should know i play with them alot im thinking M24)
    but i dont think the first will have the flow and the latter the patten
    Rohan
    Default Re: injector sizing?
    best bet is what HP you want and work out the injectors from that.
    engine will be aprox 220-250HP
    Junior Member Carport Converter 4agte's Avatar
    gze injectors would be fine for that hp i would thinks
    calculator was very handy,
    Now i need high 300s to 400CC injectors with the right spray patterns
    Or casue my ITBS can take 2 injectors per throttle do i wire them up with dual injectors for that high fuel consumption look lol
    4gaze ones are 365cc i belive
    yeah 4AGZEs will be pretty much perfect, except the twin pintle style spray
    Penrith BC
    ive got x6 2jzge ones going for cheap if youre interested
    315cc @ 38-40psi
    based on 85% max duty cycle, they should be good for 45-55hp each depending on BSFC
    easy to push that to 45-48psi as req too
    http://www.v-eight.com/tech_forum/viewtopic.php?t=200
    ../delete/ban
    tech moderator
