You can buy a hks/avo fcd or simular product for between $100-200 i think.? (i've never looked into getting one)
These products will raise the fuel/boost cut level, but it doesnt completely disable the fuel/boost cutting feature. Now..
You can buy a zenner diode (works as a one way gate.power can only travel one way)from a place like jaycar/dicky's etc and simply wire that in.(snip one wire and solder it inline, very easy) They cost about $1.00-2.00. This however completely removes the boost/fuel cut feature so you must be careful of boost spikes because they could possibly harm your engine.
Also Lance posted above^ that you can block the line going to the map sensor (possibly with two bolts on either ends or sticking a ballbearing in the line). this will completely remove the boost/cut function aswell.
Or, alternatively if your looking to buy a aftermarket ecu later done the track, most makes have the function to adjust the boost/fuel cut limit.(they have a built in fcd pretty much)
There all your choices pretty much, so its your decision![]()
