Page 1 of 6 123 ... LastLast
Results 1 to 15 of 84
Thread: 1GGTE - 3SGTE cam gears <- On the verge of a break through, looking for guinea pigs
    Default 1GGTE - 3SGTE cam gears <- On the verge of a break through, looking for guinea pigs
    hey fellas, i heard the other day that the 4AGZE vernier cam gears can fit the 1GGTE...
    anyone know anything for or against this?
    '77 RA28LT #2 ← 2.2L 18RG...
    Default Re: 1GGTE - 4AGZE cam gears
    If you can get some accurate measurements from the 1G, I can tell you I've got the 4A gears sitting next to me. Otherwise, give it a week and our 1G will be here, and I can swap them on
    RM.
    why would you swap them?
    are they adjustable?.
    blake
    blake
    i think you will find he means will 4ag vernier{ that means ajustable} not stock ones.
    i can tell you next weekend when my wife brings the soarer home! as i have plenty of 4ag ones here and a 1ggte in the soarer! if you dont find out in that time
    tell me what to measure and ill measure my 1g ones
    theyre my 1G ones, what measurements u want? diameter and shaft diameter?
    count teeth to start with, and and then radius!
    i just went out to the garage and got a 4ag one
    there better be rep in this, damn my feet are freezing now!
    counting and measuring...now!
    46 teeth
    15.96 mm inside hole
    115.69mm diameter
    sorry, i just got new digital calipers
    36 teeth, cetre hole is close and outside diameter way off! no they dont fit
    your in qld and its freezing? you must be inland!lol
    halfway between gold coast and brisbane
    im just a panzy, but i am wearing stubbies and a singlet !
    Ok... now compare to a 3S gear anyone?
    CHECK IT OUT HERE
    3S has 46 teeth...next!
    oh hold on, we're looking for stuff to fit a 1ggte right, lets look into this further, the first bit is right
    May 2006
    Virginia, USA
    IF the gears fit, but the teeth are wrong, see if the timing pulley from the motor the gears came from will fit the crank of the motor you want to use. If so, problem solved... though you'll most likely have to modify the timing cover if the cam gears are WAY oversize (i.e, I wouldn't go putting 7M gears on it (which are 48 teeth))
  1. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 07:15 PM
  2. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  3. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
  4. 4agze conversion
    Last Post: 02-03-2006, 08:52 PM
  5. How to connect 20V alt to 4agze loom?
    By d-shiznit in forum Tech and Conversions
    Last Post: 25-11-2005, 07:10 AM
