Results 1 to 6 of 6
Thread: 4age rwd or fwd
    Junior Member Grease Monkey imlach74's Avatar
    victoria
    Default 4age rwd or fwd
    im in search of a 4age for my ta22
    and from everything i have read getting a rwd out of a sprinter is the best to do
    but............i cant find any....there is heaps of fwd setups....if i was to buy a fwd is it much harder to attach the rwd gearbox and fit it in the car??
    thanks
    edit: you cant force bold your topic, ed
    Default Re: [B] 4age rwd or fwd[/B]
    Have you read Karl's excellent article in the Tech FAQ on exactly this topic?
    Mos.
    Penrith BC
    clearly not
    ../delete/ban
    tech moderator
    Penrith BC
    ../delete/ban
    tech moderator
    victoria
    Default Re: 4age rwd or fwd
    so that means it wil fit into my ta22?
    T'ville, QLD
    dude please do some research!!! basically the difference between the rwd and fwd 4ag's is the water pump and ancilleries (excepting 20v) i am currently researching a 20v into my '22.
    basically there is a bit of fucking around with a welder to be had with mounts and crossmembers, and a bit of difficulty with sourcing a bellhousing, depending on whether you get an adm or jdm housing, one of these will reqire you to swap clutch slave and re-rout lines, (cant remember which one). if going 20v need an ae82 remote thermostat and a few odds and ends for re-routing water, also either a hole in ur wall or covert to coilpacks and unless you want to make a manifold and get an afm and piping going an aftermarket ecu will help greatly (and comes out on top when looking at a cost benefit analysis)
    so in short read, ask me any q's ya need also talk to sam q, slydar and monk on ae86 dc
    and dont ask any of the aforementioned "how do i do this conversion"
    2T out 4A in....
    Last Post: 17-06-2008, 08:53 PM
  2. big port 4age comparisom
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 03-04-2006, 08:12 PM
  3. 4age engine mounts
    By duff_boy in forum Tech and Conversions
    Last Post: 03-03-2006, 12:35 AM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
