Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 139
Thread: Turbo Preference for 4age
  1. #61
    sa
    Default Re: Turbo Preference for 4age
    id say it would be more like 13 psi from the middle graph
    oops! Blind I am.
    That's a very nice power curve and a nice bunch of power for a mere 13psi.
  2. #62
    Junior Member Grease Monkey faulksy's Avatar
    Quote Originally Posted by myne
    And oh does it launch when it hits 5k
    In 3rd gear, at what's already a stupid speed, 5000rpm comes round and you can see him struggling a little with the steering as the wheels try and break traction. Problem is, even at that speed, it takes no time at all before its on the redline.
    i was in perfect control never seen a car get from 100km/h to off the dial so quickly. thats if i ever intended to do that of course
  3. #63
    Junior Member Carport Converter 4agte's Avatar
    i dunno about being too big
    . 50 A/R COMPRESSOR
    .63 A/R TURBINE
    my gt2535 is .64 a/r
  4. #64
    Quote Originally Posted by 4agte
    . 50 A/R COMPRESSOR
    .63 A/R TURBINE
    your 2535...when does it make boost? is it laggy? do you have a dyno sheet to prove?
    also your 2535 would be ball bearing yes? this T3/4 item isnt and ive found they arent as responsive when they are a plain bearing item...
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  5. #65
    sa
    Quote Originally Posted by faulksy
    Never said you werent, just pointing out that it gets a bit twitchy when the boost hits
  6. #66
    i have strong beliefs in the uber value to performance ratio of the WRX turbo. You can pick them up for around $200 a lot of the time, and with a good manifold and the right build.... you can be happy with something like this:
    Courtesy of teh freak, Diz. Custom JMR manifold, stock (enough) bigport 4agze engine.
    ...... butt scratcher?!
  7. #67
    This is not a highly backed up opinion but if you only want 7psi i know i guy that used to have a 4A in a rolla that he bolted the turbo off a CA16 (nissan EXA or simillar) onto, and it would spool almost instantly and boost 8psi to redline. I think he mumbled something one time bout too much exhaust manifold pressure at top end but the guy is a "backyard perfectionist"
    All i know is that red rolla was bloody quick. Dunno where the car is now coz i haven seen the guy for ages.
  8. #68
    i dont think the t3/4 would be as laggy as a gt30 which is what i would consider too big
  9. #69
    i agree. whenever every asks me what turbo i have and say "gt30" the respond you mean "t3" some people dont believe me until i pop the bonnet to show the monster underneath.
    i reckon a good t3 would be nice on a 4age. not for me though as want something gt spec
  10. #70
    ......................... Carport Converter
    How much and where are good places to get wrx turbos's from?
    Michael
  11. #71
    Z imports in adelaide have a poo load of them last time I checked...
    08 82447911
    cheap too
  12. #72
    OK cheers, ill try them if i can't find any locals...
    Do you know wat they were selling them for?
    Michael
  13. #73
    Offset is king Grease Monkey monkeymajik's Avatar
    http://www.wrx.com.au/forum/
    http://www.rexnet.com.au/
    http://www.mrtrally.com.au/
    performanceforums is also okay.
    I picked up the td05h-16g on rexnet. Heaps of cheapies around
    monkeymajik
    "Recommended for those who prefer
    hot driving action and big angle drift."
    JDM Style Tuning - Super Late Braking Technique!
  14. #74
    Ok cheers,
    Michael
  15. #75
    . 50 A/R COMPRESSOR
    .63 A/R TURBINE
    The GT30 can be a far more responsive turbo than a T3/T4, in fact if they are both rated for the same power the GT30 will definately spool better because of the newer aerodynamics. If the T3/T4 is a 57 trim like all the cheapy's from china then it will be a dog for spool times.
    You have to remember that A/R is a ratio. You can't just compare the number between different turbo families. A T3 0.63 housing is a hell of a lot bigger than a T25 0.64 housing. Or even better example my TO4 has a 0.58 housing and it hits 10psi at 4500rpm on my worked 3S. Physically the turbine housing is at least 25% larger than a T28 0.86 housing.
  1. **HELP** Twin turbo to single 1jz setup.
    Last Post: 11-07-2011, 12:06 PM
  2. 2jz-gte Turbo Oil Feeds
    By dori dori in forum Tech and Conversions
    Last Post: 05-01-2006, 11:26 AM
  3. 5mge turbo
    By pete05 in forum Tech and Conversions
    Last Post: 18-12-2005, 08:23 PM
