Results 1 to 10 of 10
Thread: Where to mount water temp sensor on 1g
    Default Where to mount water temp sensor on 1g
    Hey i usually mounted them into the thermostat on my other cars, cant on the 1g,
    so other 1g owners, where should i mount the sender?
    Stomps
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default Re: Where to mount water temp sensor on 1g
    *** not a 1G owner**
    but here goes,
    i know that people with the classic celicas are either doing the popular excel radiator conversion which has a place for you temp sensor to screw into,
    or you could just stick it into the top radiator hose, and add sealant,
    DQIKST
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Junior Member Grease Monkey glytch's Avatar
    Quote Originally Posted by DQIKST
    ...... the popular excel radiator conversion which has a place for you temp sensor to screw into,
    Noooo! I Pefer to think of mine as a Gemini conversion. Well thats what the sender was for.
    RA40 Coupe - Even more Turbo beating ponies.
    "Give a man a fire and he's warm for the day. But set fire to him and he's warm for the rest of his life."
    haha, i dont really wanna jam it into the rad hose, nor change radiator.. but the rad hose bit gives me an idea..
    i might fabricate up a little pipe section to thread the sender into, then cut the radiator hose i 2 and mount it in between..
    Any other ideas
    Stomps
    I didn't change the radiator - I removed it and took it to Natrad for them to weld a nut onto it.
    I provided the nut too.
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    Thats what i did, I used a piece of mild steel i scabbed from my local exhaust shop and tapped a thread in it screwed the temp sender in with a bit of sealant. I welded some steel mounting brackets to it so it would earth the sender then used it as an extension for my top radiatior hose due to my engine conversion.. too easy
    o and dont forget to paint it black
    umm, whats wrong with the stock temp sender locations....
    theres one that screws in a bit below the thermostat housing on the front and there are the 2 for the ecu on the exhaust side of the engine, just below the thermostat housing again...
    Western Aus
    easy peasy.
    Eldar.O.
    yeah i know who owns the car, and its currently my desktop background, he should be flattered!
    I used the original temp sender to suit the oem dash cluster temp gauge.. it has a smaller thread on it than the one on the new motor.. i had to use the original temp sender otherwise the gauge would not read accurate.
    thats what i did in my ke70. the temp sender out of the 4k matched the 1g one perfect, only read different
  1. Cooling Systems - Overheating Problems.
  2. 1ggte water temp sensor
    By Big rob in forum Tech and Conversions
    Last Post: 29-03-2006, 01:15 PM
  3. Water temp gauge install
    Last Post: 21-02-2006, 10:45 PM
