Probably true but you might want to check the ball joint arrangement before you get carried away.
I know 30 series and early 40 series Hiaces had balljoints which both pointed down, and the the RH41 onwards had a more conventional arrangement, with the lower ball joint pointing up and the upper ball joint pointing down.
I can't be 100% sure that it isn't the same for Hiluxes of that similar era.
