This would be a worry at WOT.Originally Posted by dale30
If there is enough vacuum to create that much of a temperature drop around the carb, i would think the carb isnt big enough.
Any photos of your setup?
Sounds interesting.
have you measured the intake manifold temp with a thermometer? i'm curious to know how significant a difference there is in relation to ambient air temp.
Sounds interesting.
Daily: Toyota '05 Rav4 Sport
Have not tested temp but ice is bloody cold.
350 holly is not a small carby.
Heres a link to photos. Just pulled the motor back out soI will take more tonite.
http://toymods.net/forums/showthread...862#post271862
XT130 speedway car XT130 road car
2 x Renault Fuego speedway cars
02 TS50 falcon
Light travels faster than sound. This is why some people appear bright until you hear them speak
Ok, well that means itll be from a lot of part-throttle use.Originally Posted by dale30
I would be worried about the butterfly freezing up.
This is exactly why carb inlet manifolds are heated.
Thanks for that.Heres a link to photos. Just pulled the motor back out soI will take more tonite.
Im considering getting a SC14 for my 21R for some cheap thrills.
It would be setup almost exactly like yours, but using a Weber 34ADM carb.
BTW... isnt the Holley 350 too big to meter low-revs/high-load fuel properly?
Or does the SC14 make that job easier?
This is a speedway car so its getting heaps all the timeOriginally Posted by MWP
Butterfly wont freeze..It only freezes below carby at wot.
Its not that great down low,For what you want a falcon xf webber will be perfect.I was running one on the 18R and the standard jetting was perfect. Fuel consumpsion was great to.8 ltrs per 8 laps with the toyota carby jetted...2 ltrs per 8 laps with stock webber.
heres some more pics i just took.
02 TS50 falcon
Ive been running the 34ADM for a few years now, before on my old 18R and now on the 21R.Originally Posted by dale30
The standard jetting wasnt right, so i tweaked it a bit, and then again when it went on the 21R.
I get decent fuel usage around the city, 9.14L/100KM (on ULP92) and thats with the occasional thrash through the hills.
Leans out a bit top of the primary though which i need to fix.
You are right, i also think itll be the perfect carb for draw-through with a SC14.
Thanks for the new photos.
