Results 16 to 18 of 18
Thread: 4agze popping at hi rpm/now lack of power
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Default Re: 4agze popping at hi rpm/now lack of power
    It is possible to idle with 0 degrees spark advance
    Edit: Did you time it to 10 degs with E and T1 shorted on the check connector?
    == 4AGZE SC14 Supercharged ==
    Oberst Koi-Master Backyard Mechanic
    Sounds like my ZE when it was first running, though the fact the idle had to be bumped up quite a few turns should have been a sign that something was wrong.
    It seemed to run fine, but had no real grunt. We noticed the exhaust manifold was glowing after very short drives up the street and back. It ended up being the exhaust cam was a tooth out...
    If I were you I would be pulling the crank pulley off, checking that the notch in the crank timing pulley aligns with the bump on the oil pump body, then you are 100% sure its where it needs to be, then double check your cam timing, then put the pulley back on and check your new timing mark for correctness, then check your ignition timing.
    And as above, time it using the AW method.
    "Welcome the dude who ain't the buyer of mugs"
    BOTTLE FED 1st year Apprentice madrolla68's Avatar
    Jun 2006
    W.A.
    Quote Originally Posted by bassy
    ok people heres an udpate, i checked over all the cam timing and that seems ok, crank pulley must have slipped so i put a new mark on it using #1 at TDC. Then noticed that 3 and 2 plugs were switched around on the coil packs, so i switched them round.
    Then i started it up then checked the timing and its at 10 on the block... everything looked and sounded fine, so i took it for a drive. putted around fine but when i went to give it some it dosent really go. dosent die or anything just has no grunt. PSI is reading about 10...
    not really sure what to do.... should i just go get a tune and dyno?
    thanks people, bassy
    HAve you checked the fuel pressure!!!!!!!!!!
  1. 4AGZE in to 4AGE AE82. (now with CV shaft info)
    By Striker in forum Tech and Conversions
    Last Post: 28-12-2006, 02:53 PM
  2. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  3. 4agze conversion
    Last Post: 02-03-2006, 08:52 PM
  4. 4AGZE Tech info...
    By puzzle man in forum Tech and Conversions
    Last Post: 04-02-2006, 01:13 AM
  5. 4AGZE Tech info
    By puzzle man in forum FAQ
