Results 1 to 11 of 11
Thread: 7mgte flywheel to 7mge ?
    Default 7mgte flywheel to 7mge ?
    hey i was wondering if the flywheel of a 7mgte will bolt onto a 7mge?
    Default Re: 7mgte flywheel to 7mge ?
    Yes.
    But they are different, remember that if your thinking about bolting it upto anything but a R154 transmission.
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    As they both said Both flys are incerchangable crank side, but one os fora push type cluch, the other for a pull type..
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    thankyou for the replys really helpful
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    I have recently setup a 7mge clutch on a 7mgte flywheel. The dowls are in the correct position but you will need pcd drilling to be done for the pressure plate bolts. my local clutch place charged me about $100. Note the only reason i did this was i couldnt find a 7mge flywheel at the time.
    I think James, Viper_nipples did this too.
    *coughreptoallcough*
    what have I done?
    Use a 7MGTE flywheel with a W58, or was it Ryley? I'm sorry really cant remember, been working too late this week which has affected me memory...
    vic
    the gte flywheel is fatter tho , would make the clutch release bearing sit in a different spot
    Dave
    penrith nsw
    seems to work ok on mine
  1. Project 7mge to 7mgte %90 done -%10 need help
    By Mk3_supra in forum Tech and Conversions
    Last Post: 12-08-2006, 10:38 PM
  2. 7mge cams into 7mgte
    By rollsy in forum Tech and Conversions
    Last Post: 21-07-2006, 08:17 PM
  3. 7MGE injector plugs same as 7mgte plugs?
    Last Post: 23-04-2006, 12:28 PM
