Results 1 to 8 of 8
Thread: Puzzling blinker problem. Mz10 soarer
    Junior Member Grease Monkey Jag7799's Avatar
    Default Puzzling blinker problem. Mz10 soarer
    hey lads,
    Its been a while since I've been on here.
    My JZZ10 is being an absolute git.
    My indicators are blinking really fast as if a bulb was blown out.
    All bulbs are working. I replaced the relay just in case and its still doing it.
    Hazards go at normal speed.
    Any idea's?
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Default Re: Puzzling blinker problem. Mz10 soarer
    You don't have a body kit that has removed some of the indicators from the system?
    regards
    jon
    Junior Member Backyard Mechanic ndgcpr's Avatar
    These cars are renound for corrosion. I bet your rear light warning comes on too. Basically all of the plugs on the rear end corrode and pull less current. All your lights still work fine but due to a lower load being placed on the circuit they flash faster. Pull out your bulbs and give them a little sand and it may fix it up.
    For the record my passenger side flashes faster the the drivers, wonder if it is the same as yours?
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    All fixed.
    I was being a retard and in a hurry, and accidentally put 24w bulbs in the rear ones, instead of 12
    Western Aus
    my supe has this same problem, all work, but left flashes faster than right, i think its time to swap the left side out :/
    Eldar.O.
    Just check that they are all 12w bulbs.. I was ready to call a fucking auto elec.
    Low Down Style Domestic Engineer Johnzoku's Avatar
    queensland
    sorry to dig up an old thread but ive got this problem as well...
    were working fine before i got my new alt. put in and now the passenger side is blinking faster as well...
    all fuse's and bulbs are good altho i will have to double check there all 12v ones but i cant see them being other wise (they were working before the new alternator was in).
    the new alt. puts out 13.8v with lights off, 13.4 with lights on... the auto sparky said he put in a 55amp alt but wasnt sure :S thats less than standard im pretty sure. could the lower out put cause this?
    this is on a 6Mge as well.
    Stock 5M/6M alt is 60A, so the new one is fine.
    Should affect anything though.
    Most likely just a coincidence.
  1. MZ20 Soarer starting problem
    By whatthe? in forum Tech and Conversions
    Last Post: 05-03-2006, 05:19 PM
