Results 1 to 9 of 9
Thread: Radio Installation Problems
    CA
    Default Radio Installation Problems
    So i just started installing my new pioneer deck in my MA6, the only problem that I ran into is that a part of the deck is hitting somthing that is in front of my heater assembly, Iam assuming that is has something to do with me heater system but I can't find it in any shop manuals
    Default Re: Radio Installation Problems
    what does it look like?
    dont install it in the top section... it has to be put in the lower din slot.
    JZA61
    Guest
    yeh the jb hi fi bloke said that to me, he also said that u can take out the casset player and buy a little slot for small stuff that will fit perfectly from the store if ur gonna put in rear speakkers u need 4 buy 3 inch ones, i went vdo titanium cone but dont expect bass lol. but speaking of bass aparently the ma61 came out with a mid range speaker or (80's sub if i may) in the passenger side lower dash, under the glove box LOL so you can play all of those mega bassy 80's tunes like michale jackson and NWA. crank it
    Equipped with Bowls Hat Backyard Mechanic Adam_Cressi's Avatar
    i think whatthe? is the one to ask, his audio setup sounds awesome. well thats my opinion, ( as an audio engineer)
    2JZ-GTE MX-83 Cressida
    Toymods Car Club Club Member # 185
    JZA61
    Guest
    oh okok sorry didnt mean to insult thy hiness with more rep than thy. i meant if u dont want to chop up the interior u have to buy the small ones. so u can put them in the stock brakets.
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    That metal thing is the DVV or something along the lines that operate the climate control. I installed mine radio in the lower din slot.
    JZA61
    Guest
    oh ok. i see jb dude said it was a mini amp.
    CA
    It goes from the center to the right side. the unit is that goldish color that you get with grade 8 bolts. the left side of the unit has a box with an actuator lever on the top. on the right of the unit is a drum that looks like it has a diaphram inside of it. there are two part numbers on it but i can't figure out which one is the correct one. 113800-0274 & 88660-14040. Is this peice important to have in? I done really use the climate control as it is. Will everything else operate without this peice? Thank you, all help is greatly appreciated
  1. Problems solving 4agze
    Last Post: 28-06-2006, 06:21 PM
  2. 1G-GZE - My Problems !
    By ra23celica in forum Tech and Conversions
    Last Post: 20-03-2006, 12:21 AM
  3. Radio Feedback and temp question
    By ripfast in forum Tech and Conversions
    Last Post: 08-03-2006, 11:47 PM
  4. 2T-G/3T Hybrid Compression Problems
    Last Post: 05-02-2006, 07:03 PM
