Results 16 to 28 of 28
Thread: my Celica is blowing smoke - info wanted please
    Default Re: my Celica is blowing smoke - info wanted please
    Remember to unplug your ignition coil output lead before doing a comp test, you dont want it actually starting on 3 cylinders while you are doing it.
    Also, dont touch wood for the rain to stop, we still need rain.
    Chris, plugs should be out of all cylinders anyway when doing the compression test.
    If budget extends, I would recommend buying a compression tester that actually screws into the spark plug hole rather than a cheap and nasty Supercheap type that pushes into the hole. Usually, this is the cause of most test variability.
    Hope you're not too late Takai! Important.
    Quote Originally Posted by gianttomato
    Yeah, i picked a screw in type up for $40 on ebay... aurora tools or something... havent used it to see if its all good yet but should be ok...
    Toyota Car Club (Qld)
    Junior Member Grease Monkey minxgirl's Avatar
    The goddamn rain didnt stop! I think you jinxed me takai *LOL* we are even getting hail here from time to time!
    Im all paranoid about my car I dont want it hailed on, and I wanna change the oil (it's new oil in it but its thin and crapped out), and I wanna know what the compression is doing *tears hair out* I have a sinking feeling that the results of that test are gonna be bad *sigh* /end rant
    Also Im looking more and more at that smoke its blowing and I think it is bluish white...
    OK did the oil change - now Ive lost my electricals WTF...
    Just a quick update - changed oil yesterday and cleaned plugs...didnt get to the compression test - but I have the tester now and Im hoping the break in the weather holds off enough I can do it when my b/f gets home and can mind the kids at lunchtime today Having some electrical probs but I made another thread about that...
    PS. I am pretty proud of myself - it was the first oil change *I* have actually ever done and I went it alone *we* have done plenty - just that Id never done it *LOL* (It was way easy once I bought a new socket set cause the b/f is a toolwrecker and his 3/4 was literally broken )
    if you have any more probs, bring it up 2 me at midas hornsby....if your anywhere near hornsby...i'll do a compressiomn test in front of you,....
    gluck, blake
    Thanks for that Its really nice of you to offer - as it happens I am a long way away *LOL* Im gonna do the compression test this arvo Just waiting for my boyfriend to get home
    Compression test done...*sigh*...
    dry test:
    135
    140
    140
    140
    wet test
    170
    170
    210
    170
    I assume this means I need new rings...is this how petrol could be getting in the sump?
    OK so Google tells me the petrol getting into the sump is the compression rings, and the oil burning (smoke from exhaust w/e) is the oil rings....
    Does that sound about right?
    Jill,
    Just found this thread. I have already replied in your compression test results thread BUT. 2 things of note for your DRY compression test. Dana has it covered well but some extra info.
    1stly the test has to be carried out on a warm engine, not a cold one.
    2ndly the test must be carried out at wide open throttle, ie accel foot to the floor
    When does the car blow smoke and for how long ?
    What oil are you using ?
    Oh and check your breathers. If they are blocked it will presurise the engine and push oil past the gaskets.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Sydney N.S.W
    i've been following this process and tried it yesterday.
    This is on a 18rgu +E (EFI) 18RG CAMS, 9.7 COMP PISTONS.
    IT HAS BEEN REBUILT BY ME, A House mechanic.
    new rings. wet test is at 135 - 140 on piston 1,2,4 piston 3 at 100.
    I did not have the engine at operating temp, won't start alarm kill switch problem.
    Would No. 3 be due to A. new rings not turned correctly ie. gaps to close on oil& fuel rings.
    B. valve not sealing
    C.other, your call.
    head was good on visual, I'm unsertain on timing though, I doubt that could be reason for 1 cyl to be out.
    any help. maybe this Q will extend from current thread if not sorry for Hi-jack.
  1. 20 valve TB info wanted - measurements
    Last Post: 24-03-2006, 05:02 PM
