Results 16 to 18 of 18
Thread: Corolla, clicking noise on wheels while turning.
    Default Re: Corolla, clicking noise on wheels while turning.
    mmmmmm yeh when its back next, ill take wheel of and make a better inspection, thats a good suggestion, as about 8 months ago we put sum kings and shockies into it, perhaps sumthing from that... mmmmmmmmmmmm
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    Have you tried putting the car on stands and spining the wheel? Can you feel any resistance and can you hear the noise if you are rotating the wheel by hand?
    Then, remove things until the noise / resistance stops and investigate that part.
    Remove the wheel, rotate, listen. Remove the Caliper, repeat. Remove the rotor, repeat. Remove the CV, Repeat.
    If you cant stop the noise with the above process, You might be able to isolate it to the hub / suspension. Start wobbling things!
    Although, if you cannot feel or replicate the issue when rotating by hand, this may make it harder.
    Good Luck, its there somewhere...
    Check your suspension components. When s/bar link bushes are rooted you'll hear a click on turning. Also check any other rubber bushes by spraying them with crc, then bouncing the car, turning the wheel or road testing if needed. Do them 1 by 1 so you know which one it is ( if ) it solves the problem.
  1. Replies: 47
    Last Post: 16-01-2006, 05:08 PM
