Page 16 of 27 FirstFirst ... 6141516171826 ... LastLast
Results 226 to 240 of 398
Thread: Project 6-speed
  1. #226
    Default Re: Project 6-speed
    its a getrag...they dont break
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  2. #227
    sooooo ... how long before the diff dies then?
  3. #228
    I've got my money on driveshafts first.
  4. #229
    Who says Getrag's don't break - they had better tell my gerabox that story.
    Mine comes out next week for another round of synchro's and hubs yet again - and I don't thrash it at all. Hasn't even had a burnout done with it yet. Must have bought a brumby model from Japan.
    Graham D
    Lexus RX350 (no mods yet !!!)
    Lexus IS200 / 2.5GT-T (1JZGTE VVTi + Getrag 6 Speed)
    Lexus IS200 (wife's car and no mods allowed !!!)
    Suzuki GSX750-F
  5. #230
    I think your problem might be lack of burnouts.
    Chuck a few skids & a couple of doughnuts once you get it back together, then repeat on at least a monthly basis (preferably weekly) and I'm sure your box will live a longer happier life.
    If not, make sure you film it.
  6. #231
    I'm pleased to report the V160 is now sitting in its new home, and with any luck won't be coming out again for a very long time! It actually goes in much easier than a W58 because you don't have to worry about lining up the splines; the clutch is already sitting on the input shaft and you bolt the pressure plate to the flywheel after the transmission is bolted up to the engine, just like with an auto. So all you have to do is find the spigot bearing and the rest is easy.
    There's a bit of work left to do though. The top bellhousing bolts are much harder to get at now so I need to buy a longer ratchet extension before I can finally bolt it up to the floorpan. The hydraulic line isn't long enough to reach the slave cylinder so I'll have to find a longer rubber hose section (it's the same as a brake hose so that shouldn't be a drama). The biggest worry though was the crank pulley coming undone as I was turning the engine over by hand, and with very little effort too! That bolt is meant to have 300nm of torque on it so I hope I haven't destroyed the keyway in the crank. For now I'm going to get the biggest breaker bar I can find and lean on it with the help of a friend or two, not sure if I'll manage 300nm but I'm sure I can do better than how it was!
    After all that's sorted I just need to find the cash for a tailshaft and it's time to go driving.
  7. #232
    Sounds great norbie! If the crank pulley bolt is already loose, i'd take it off and check the keyway before trying to put 300nm of torque on it! Just to be on the safe side.
  8. #233
    Yeah I know, but that means the radiator comes out and Norbie is not keen. Besides I might see something I really don't want to see!
  9. #234
    Better than finding out the nasty way after! I'd do it now, it's not as if you're relying on driving it atm!
  10. #235
    she'll be right
    have some stupidly long etensions if you need norbie, 600, 450 and 300 in 1/2 and 3/8
  11. #236
    30kg of force at 1m. (horizontal bar)
    20kg of force at 1.5m
    should be able to do it easy... with a piece of pipe
    you get get tricky if you wanted to do it "accurately".. with a vertical bit of pipe, horizontal rope, a pully and some weights not quite a WST, but close
  12. #237
    More progress this weekend, and I got photos this time!
    Here's the custom fuel lines, haven't got around to hooking up the hoses yet but that shouldn't take long:
    I managed to tighten all of the bellhousing bolts (I needed 5 ratchet extensions to get at some of them) so the box is now bolted up properly, and the external shifter bracket fits with no clearance issues much to my relief.
    The transmission tunnel got a final coat of white paint so it doesn't look so crap, and I re-installed the carpet and seats so it looks like a proper car interior again. I didn't get around to hacking up the centre console, that will come later.
    More photos here.
    It's getting very close now! I just need to finish the fuel hoses, extend the hydraulic line for the clutch, and buy/install a tailshaft - then it's driving time! I can almost smell the burning rubber.
  13. #238
    Console??? Come on Norbie, all that effort, you don't want to ruin the ghetto look now by installing the console
    seriously though, nice work and warrants DIY applause
    Tasmania
    Good work Norbie it's come a long way since I saw your car. In 4 years its bee re-shelled new brakes gearbox suspension and eaps of other things. I sold mine but am getting into a cressida and going for the 1j engine swap and auto so my wife can drive it. Maybe I should just go for a 6 speed as well, and a 2j! Hmmm maybe not.......$$$$
    Rich
  15. #240
    Yup, thats looking awsome Norbie. Its going to be a madly insane car to drive once this is done.
    Just had a thought, your not going to use the century to tow the supra to the driveshaft place i hope
  1. Classic celica suspension TA23
    By WindeX in forum Tech and Conversions
    Last Post: 12-01-2007, 08:54 PM
  2. KE 35 conversion from 2 to 3 speed (auto)
    By woody012 in forum Tech and Conversions
    Last Post: 02-01-2006, 10:12 PM
