Results 1 to 8 of 8
Thread: ECU Reporting Intercooler (54) Problem
    Default ECU Reporting Intercooler (54) Problem
    i was just woundering if anyone else has had the ECU report this problem and what they did to fix it. i am guessing it has sumthing to do with the sensor in the intercooler. does anyone know where i can get a replacement from if this is the case?
    Default Re: ECU Reporting Intercooler (54) Problem
    is this for the ST165 engine in the GT-2?
    From gtfours.co.uk;
    54 = INT = Intercooler Coolant Low or Pump Failure
    Top up IC fluid reservoir, (not applicable to 185), test IC water level sensor, test IC water pump. Tip - run car with IC cap removed, blip throttle, watch water level drop, add fluid to max level, swiftly replace cap
    yeah it is for the 3S-GTE in the GT2, i'll give that a try and see what happens
    is that the error that it came up with ?
    I belive Karl tripped it to Run the IC constantly, could this be related ?
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    yeah thats the reason the engine warning light has been comeing on. might have to ask karl if thats why this problem is happening
    doesnt that mean its just the water to air intercooler has low water
    the intercooler has a small radiator cap on the top and it has a level in it
    u might need a resistor across the wires if your not running it
    nah, i had that cooler filled up to brim most of the time, and still had that engine light...
    then check resistance in that sensor thats if the code relates to that
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 07:10 AM
  2. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  3. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
