Results 16 to 18 of 18
Thread: balancing clutch/flywheel
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Default Re: balancing clutch/flywheel
    Quote Originally Posted by DaveW
    ...my understanding was id lose torque from a lightened flywheel in an NA, something i rlly want to hold on to....
    You dont actually lose torque with a lightened flywheel, all it does is change the way the torque is delivered to the drive train. If you have a light car I would go for a lighter flywheel, if the car is on the pudgy side a heavier flywheel is better.
    A flywheel will store as well as sap the engines momentum, so off the line an engine with a light weight flywheel will need a few extra revs to replace the lost "torque" or momentum of the flywheel. Once the car is rolling the engine will be able to gain revs quicker as it wont have to spin the weight of the flywheel with it.
    Good explination Enchanter.
    Always compromises to consider in any build.
    Regards
    Rodger
    Junior Member Carport Converter DaveW's Avatar
    well i picked up the flywheel and clutch, the guys did a nice job machining it, really nice ppl to talk to as well, his name was Rob from Transmission physician in hornsby. he said it wouldnt need balancing because it was balanced from factory, and that unless it was gonna be revved beyond 14 000rpm then it wont need a balance.
    Dave
  1. GZE and GE clutch/flywheel interchangability
    By mullett in forum Tech and Conversions
    Last Post: 24-03-2006, 10:25 PM
