Front brakes do about 80% of the work of your braking system.
you should NEVER install a proportioning valve on the fronts as you are limiting the amount of force you can exert on the pistons on the front calipers. This is REALLY REALLY bad.
A problem you may have with your brakes is that you may have not designed it correctly taking into account the loading on the fronts vs the backs and selecting appropriate rotor/caliper sizing. Having significantly larger rear rotors is going to induce heavy rear bias. Proportioning valves aren't going to do much when you have such a large imbalance in the braking power front/rear. What size master are you running? What are the piston sizes front and rear?
When you say you had 'so little brake bias' - what do you mean? were you locking the fronts before the rears? or vice versa? You should always have a little bit of front bias - ie fronts locking first as rears locking first is quite dangerous.
) it seems that if you install one on the front you will be giving your brakes progressively less pressure as you brake harder. This is bad as with forward weight transfer when you brake at very low speeds you want brake bias (force not hydraulic pressure) to be approximately 1:1 and as braking force increases you want the bias to move towards the front.
