indeed, thanks to everyone for the rep, much appreciated
after hearing the noise those MSD things make, I thought it was time.
never mind, enjoy the rep - about time this was spelt out simply and easily as you have done.
saves some sucker, what, $140....
../delete/ban
tech moderator
Make, thats terrific! Top stuff even if the pictures are blurry. Adding to my Parts number and watsicallit thread.
MA61 Part Numbers, Upgrades and General Infomation <--- Clicky Clicky
Originally Posted by cuzzo
this works in theory. would need a 5-6V voltage regulator and a 741 op amp. wouldnt be too expensive to make
hello
my car ECU produce square wave tacho signal but im having an old ST183 meter cluster...![]()
its tacho has 3 connection points...
anyone can tell me which points is Vcc, GND and tacho signal?![]()
how to adapt this gadget to work with my old meter cluster?
i wouldnt like to cut my ecu connector's wires...
thanks mate
Great write up James... Glad to see you making it smaller!
Originally Posted by ViPeR_NiPPleX
what does the voltage spike to?
hello
In car I measured over 200V...(edit: stock coil system i.e. 5M-E)...Originally Posted by brett_celicacoupe
it might be sensible to put a flyback diode and resistor then.....
my cheap electronic sim program is reading a >500V spike
now, with a diode in there;
like so
dodgey circuit program 101 response;
more like a 50V spike - so maybe more like 20 in real life.
maybe someone could experiment, someone with their dash already pulled apart. my tacho is rather limp sometimes.![]()
hello
Brett, you are missing the point, the back emf spike is what drives the old style tacho systems...
If it ain't broke (and it isn't) why add more compoents to it?
Originally Posted by wilbo666
+ rep for being gun.... and a nerd.
because mine is broke.... its limpOriginally Posted by wilbo666
hello
The factory high voltage spike is around 40V peak (at least in an MX83).
I use a zener on my units to clamp the spike to something more sensible. You can also use a capacitor to reduce the height and increase the width of the spike.
Mos.
HeyOriginally Posted by ViPeR_NiPPleX
I've made one of those adaptors cos my 7ma61 tacho doesnt light up. But when i went to install it last night i wasnt sure where to plug/solder it in! Where do i find the said wires/plug? Photos or a description would be sweet
CHEERS
