I would recommend getting a spring that is rated at whatever the lowest boost pressure is you want to run. So if you want your low boost setting to be 7psi, get a 7psi spring in the wastegate.
Then let the boost controller do its job and bleed off air to the wastegate hence raising the boost levels.
Joel
