that depends where the restrictor is...
for the sense line to controller...
if there is a restrictor near the engine, then it could slow response (as it fill the line between engine and controller, thru the restrictor)
but if there is no restrictor, or it is close to the controller, it shoould be ok.
for the line to the wastegate... well.. i dunno exactly how it works.. but it's the same principal... a large tube with good access to pressurised air will change pressure quickly, but if restricted, then response slows...
in vague handwaving explanations...
edit: the MS guys tried some long length of rubber tube for the MAP sensor.. (like 20feet??) and found it to not make much difference (was not a restricted line), but that was vacuum and not boost.... and not a boost controller![]()
