Is the block capable of supporting that?
I've heard that both Nissan CA18 and Mazda BP pistons fit. Has anyone actually tried it?
Is either piston any good stock?
Apparently 83mm is the upper limit.
Once again, I'd like to find someone who has done it before I start shopping....
I was very seriously looking at going to 83mm for the new engine, but I got nervous as to how thin the bore walls were going to end up so I wussed out and went for 82mm.
That's the 7A block though, it may well be a little different.
Hm, i wonder what the extra displacement would be for 83mm over 81mm...
Edit: For a 7AGE it would come up to near the 1900cc mark, which interestingly is what Dave Loftus is running according to the entry regs. I wonder if they have just bored it out to 83mm?
1682cc with stock stroke for a 4age![]()
If in doubt power out
Aye, see my reply above for as to why my mind was ticking over that way.Originally Posted by 7MA61
As for pistons, the CA ones are pretty poor im sure, but the BP ones could be interesting. All depends on how much one could pick up a set for.
I'd already replied before you edited itOriginally Posted by takai
, thanks for the explanation
Close, it's 1666cc.
The website I used to calculate it lied thenOriginally Posted by Billzilla
Yep, looks like it.
83mm x 77mm = 1666cc.
Argh not the websites fault the knobhead that comes up on google lists a 4age stroke as 77.7mm![]()
1851cc by my numbers....Originally Posted by takai
i believe Dave Loftus is running an offset ground crank of some sort to get his 1.9L 7age
Yeah, but a lot of the NSW guys run to the closest 100cc to add some intentional vagueness as to their engine setup. Its concievable that an 1850cc engine would be listed as 1900cc.Originally Posted by Ben Wilson
Interesting about the offset crank though, cheers
