Where did you check the spark? From the coil or from one of the spark leads?
If you checked the spark from the spark leads and still no spark, then check the breaker-points within the dizzy (assuming mechanical points) in case they are totally stuffed or shorting to something.
A common sympton of a ballast resistor failure is the engine starts okay but dies after it starts running.
seeyuzz
river
