Okay time for an update. The dizzy has been changed and the problem went away for about 2 weeks and then returned. On a couple of occasions it has died while at a set of lights then failed to start up again.
After this happened i jiggled a few wires around comming from the dizzy, the coil, and the igniter, and then it went away again for another few weeks. More recently it has been dying everyday and i got around to yesterday checking continuity between all wires and the ecu and the igniter and coil.
From this all 4 dizzy wires gave solid continuity, the 2 wires between the coil and igniter gave solid continuity, and the igniter to ecu (BY coloured wire, pin out IGF) wire was fine. The other wire from igniter to ecu (straight black colour) and pin out IGT gave me a scattered beeping and NON constant continuity. At some points it wouldnt even give continuity at all.
NOW, what is the solution for replacing this wire in the loom??? Idealy id like to just tie a new wire to the old one and pull the old one through while at the same time pull the new one through also but the wires are taped within the worm tubing. What are the other options?
- LeeRoy
