I think you're misunderstanding. When you say "thinking along the lines of 36" does this mean you want to modify the size of one of the 3T-C carb throats to 36mm? Which throat, the primary or the secondary? And what are you trying to achieve by this?Originally Posted by newbien
Not to mention that the throat sizes have nothing at all to do with jetting or "rejetting". Rejetting the carb is possible, yes, but that will have no effect on the physical size of the carburettor throats, just the size of the jets and the amount of fuel they consequently deliver.
Finally, if by 32/36 you mean a Weber 32/36 DGV or DGAV or similar, then they are (a) not expensive (relative to the cost of modifying your 3T-C carb in the manner you've requested), and (b) not actually a "twin-carb" as you've suggested. The 32/36 refers to the primary and secondary throat size and in this respect the carb is of the same design as your stock 3T-C carb.
I recommend more research and a clearer idea what you're trying to achieve, pm me if you would like me to clarify.
