Possibly.....
If you can be bothered swapping back to the stock pump you could be really sure the problem is related to the pump. I bought a $30 fuel pressure gauge off ebay and a guy at work drilled and tapped my fuel rail, thats how I determined my fuel pressure was too high and also not changing up and down with manifold pressure. I used a 100kW small-port 4AGE regulator that doesn't have the banjo fitting, rather a push on pipe fitting with a 90 deg pressed bend...that fixed the fuel pressure problem for me.
