Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 166 to 180 of 183
Thread: Turbo 5ME? (5MTE)
  1. #166
    Default Re: Turbo 5ME? (5MTE)
    Quote Originally Posted by gianttomato
    XF Falcon injectors fit easily and are 215 cc/min. Suggest trying those in conjunction with RRFPR and playing with AFM.
    We'll see, I'd like to keep it cheap without killing the motor. Tough to do but hopefully I can find a nice grey area in between being super cheap and spending too much to make it not worth it.
  2. #167
    Quote Originally Posted by RObErT_RaTh
    this is usually a recipe for disaster ... all the cheaper short-cuts come back to haunt you resulting in more cost than you ever anticipated.
    plus you could fit 6 falcon injectors in your pockets easily.
  3. #168
    Hence why I said I won't be going for cheap shortcuts, but I won't be going spending crazy like MS-75.
    The turbo has been ordered and hopefully I'll be ordering the manifold and dizzy along with some other gear later in the week. I'll let you guys know when the gear comes in.
  4. #169
    wanker Backyard Mechanic MS-75's Avatar
    use VR-VS v6 commodore ones and linish the pintle plates off. (doubles flow rate)
    Spray pattern=crap
    flow=enough
    Such analysis should fit the spirit of the project.
    Sean
    PS I expect progressive updates as parts fail and cause destruction.
    [email protected], WSID, COMPAK ATTAK, MAY 2006
  5. #170
    one upside is a set of destroyed/melted pistons that you can use as ashtrays and conversation pieces... the bent conrods are ideal for door-stops ... and the block might be a sturdy (if somewhat heavy) stand & base for a 3-burner wok/bbq (gas ring in #1 #3 & #6 bores.
  6. #171
    Quote Originally Posted by MS-75
    Spray pattern=crap
    flow=enough
    Cheers for the hint mate
    I will keep you ALL well up-to-date And turbo gear should be arriving this week, Jamie has it just about all sorted out
    Awesome, so it won't be a complete waste. I will be able to re-use some parts woohoo!
  7. #172
    Penrith BC
    lol!! so very true
    how else you think GT knows they fit
    ../delete/ban
    tech moderator
  8. #173
    Well, it's here Thanks to Wilbo and ForceFed6 I've got all the pieces required to now make this project happen I'd like to get my suspension done and struts in over the next week or two so hopefully I can work on the turbo 5me over the christmas break Will post back with some pics tonight
  9. #174
    Pics as promised:
  10. #175
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    Pics as promised:
    Looks great! Have you got the ECU that consists with an O2 input?
    Cheers.
    Can't afford it?... Don't buy/drive it...
    James (Viper_Nipplex), We will miss you - Rest In Peace - 11 March 2009
  11. #176
    Quote Originally Posted by ZZT231
    Cheers.
    Negatory, I'll be running it without.
    And hopefully I can also grab a Jaycar DFA to try and cope with fueling issues
  12. #177
    Dizzy looks like it's missing the important bit!!
  13. #178
    I'm freaking out! (runs around searching pics on pc )
  14. #179
    The cannister thing there...looks like yours doesn't exist....maybe I'm on crack.
  15. #180
    Nah I don't think you're on crack because I don't have it Is it bolted into the dizzy or just screwed together and hooked up with wires or something???
    Last Post: 11-10-2014, 01:02 AM
  2. Boost Leak Tester
    Last Post: 01-06-2006, 12:25 PM
