If you are going to swage around the edges of your filler panel,have a lip of around 10mm to sit under your roof, line it up how you want it, then drill 1/8" holes through the top of the skin down into the filler panel lip (swaged section) roughly 100mm apart ,one at a time, all the way around , following up by putting a self tapping screw in each hole
Once you're happy with the fit, take out one screw at a time, counter sink through the top skin (roof) with a 1/2" drill bit, it's tricky to not go through both panels, which you don't want to do, you can buy special couter sink bits, they are much better to use,
Well once you have taken out a screw and counter sunk the screw hole, weld the hole, then continue all the way around the roof untill its done
That method will be strong, if you want it stronger just make all your holes closer together, after doing all that you can basically leave it as is and fibreglass it or finish it off welding the seam ,but that will deffinitly be risking warpage from using alot more heat
Also remember to cool your welds it is important using any method.
Here is some pics of panels pinned/screwed into place before welding
First couple of pics on this link http://www.radrides.com/49.html
Hope that is helpfull![]()
