Check the wiring at the back is getting 12v with a multimeter (with the key turned to acc)
If it is then check the ground, if the ground's ok then the ciggy lighter socket itself is probably fubar
If there is no power then run a new wire to it, shouldn't be too hard, tap into an acc wire somewhere, put a fuse on it and a spade connector to attach to the ciggy lighter
Fortunately it wasn't too hard to get to once I had the front panel of the dash out. Prick of a job to get to if you've no idea of these dashboards.
Neither power wire nor ground were connected. Mine uses a 15A fuse, but I guess your mum's is 20A for a reason.
But then there's differences in fuse locations with different models of the same car, but I digress here.
Cheers all
