Results 16 to 27 of 27
Thread: backfire
    Default Re: backfire
    basically the car thinks its getting alot of air, which it isnt, and dumps fuel into the engine, the fuel goes straight out the exhaust ports because theres too much for it to all burn, and ignites in the exhaust, hence the popping.
    could this be contributing to your engine's immense fuel consumption on boost jorrs?
    1987 AE82 4AGE Corolla Seca Twin Cam in RED
    FOR SALE!!!
    Junior Member Backyard Mechanic ndgcpr's Avatar
    so if i mount a BOV in my 1G-GTE (AFM and no stock BOV) the same thing will happen to me. i was gonna fit one cause i am parinoid and wanted to not wreck my turbos (yeah i have read all the arguements) but i think some nasty backfiring is enough to convince me not to put one one...
    Quote Originally Posted by toaster
    Its only running EXTRA rich for a split second between gearshifts. I highly doubt it would affect the the fuel economy that much..
    Some atmos BOV's work better than others on afm cars. depends on how the car's running currently (a/f mixtures) and the adjustment of the spring setting on the bov.
    Some cars just get a small puff of black smoke between shifts, some backfire, some may even stall coming to a stop.It all depends.
    Damage to the cat is probably the only consern, maybe the smoke too.
    i think its cos i do boost it a bit to much
    Quote Originally Posted by Aust162
    hence the , meaning "not totally serious"
    (different meaning here, as in "not meant to be offensive")
    FOR SALE!!!
    i got my car keys back :> and got rego for the beast
    so now im just really broke
    Quote Originally Posted by Jorrs
    bahahahahahaha, keys
    FOR SALE!!!
    ummmm i have another question, where my bov is mounted is the intercooler pipe between the turbo and top mount water cooler, cos was only place he could get it on, is this the correct spot? i will try get pics
    it usually doesn't matter where it is placed, it really doesn't seem to make a difference, it only releases pressure not help or prevent flow in the piping.
    mmmmmmmmm yeh i odnt think mines working hey, makes no sound wat so ever ? it did when it ran 14psi made a lil sound, now at 6 psi makes nothin ? its only a 100 Dollar monza one but
    pull it off and feel how hard it is to push the spring, i have two lying around, one will undo until you can blow hard on it and it will nearly open, the other on the softest setting was still hard to push open. so at 6PSI I would think you'll need it pretty soft, i was thinking in setting mine up so it only vents under full power, and only barely vents. It should make the whole system run smoother
    Western Aus
    im going to run 6 psi on my 7MGTE, and im removing the BOV that comes with the car, simply because it wont make any difference, being AFM, it'll phuck with the engine readings too.
    that 1JZ conversion is looking better and better :/
    Eldar.O.
